The Basics
How to prepare Raspbian image
It is recommended to use nylon (not a metal) screws. Metal screws or nuts can touch some components on a camera's PCB, and in this case camera is detected, but unable to capture a video.
How to power up the StereoPi
Quick equipment test
- Open "stereopi.conf" file.
- Open console.
