The Basics
How to prepare Raspbian image
StereoPi Top Noted
StereoPi Top Noted
StereoPi USB power cable
StereoPi power cable
Wideangle camera installation
You need M2 (2mm diameter) screws. Both raspberry Pi cameras and StereoPi have a M2 wholes.
It is recommended to use a nylon (not a metal) screws. Metal screws or nuts can touch some components on a camera's PCB, and in this case camera is detected, but unable to capture a video.
https://vimeo.com/332958013
How to power up the StereoPi
Quick equipment test
  2. Open "stereopi.conf" file.
  3. Open console.
