Advanced User Section
Important notice!
Additional notices.
GPIO pinout notice
StereoPi GPIO
StereoPi GPIO
       LIBEDGETPU_SUFFIX=arm32
   fi
StereoPi and Arducam
       .led_pins = {39, 30},
       .shutdown_pins ={44, 45},
