The Basics
The Basics
How to prepare Raspbian image
- There is a two-pin white connector on board for connecting power supply. Included in your kit is a USB A power cable, with a special connector to power the StereoPi.
- If space is tight inside your robot or enclosure, another cable, like this one, can be used to power the StereoPi instead of the USB cable.
How to power up the StereoPi
