The Basics
The Basics
How to prepare Raspbian image
- There is a two-pin white connector on board for connecting power supply. Included in your kit is a USB A power cable, with a special connector to power the StereoPi.
- If space is tight inside your robot or enclosure, another cable, like this one, can be used to power the StereoPi instead of the USB cable.
