StereoPi v2 Quick Start Guide
Revision as of 18:38, 22 November 2021 by Realizator (talk | contribs) (How to use stock RaspiOS with the StereoPi v2)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
YouTube video: Power Switch
YouTube video: Hot Swap Power
Ribbon cable installation
RaspiOS Bullseye has a new video subsystem and dose not support stereoscopic mode yet!
(1) BlueTooth power indicator
dtoverlay=disable-bt
(2) WiFi power indicator
dtoverlay=disable-wifi
(5) Hot-swap power LEDs
