StereoPi v2 Quick Start Guide
YouTube video: Power Switch
YouTube video: Hot Swap Power
Ribbon cable installation
(1) BlueTooth power indicator
dtoverlay=disable-bt
(2) WiFi power indicator
dtoverlay=disable-wifi
(5) Hot-swap power LEDs
