StereoPi v2 Camera Kit Guide
10mm spacers installation
Camera installation step 1
Camera installation step 2
Backplate installation
Tripod mount installed
Camera, spacers and bolts
Elevated camera assembly
Elevated cameras installed
Recessed camera installation
Connecting the TFT screen
Screen installation: step 1
Secure the screen
Secure the screen
Screen attached
Screen attached
IMPORTANT
Connecting the button
The Button
The Button
Secure the button
Secure the button
Button pins (GPIO20)
