StereoPi v2 Camera Kit Guide
Connecting the TFT screen
IMPORTANT
- After installation of the screen, do not forget to enable it in StereoPi_v2_Camera_Kit_Guide#Turn_on_TFT_screen_support_in_SLP2.
Connecting the button
