HQ housing assembly
Revision as of 20:17, 8 October 2021 by Realizator (talk | contribs)
Carriage and CM500 filter
A drop of glue
A drop of glue
CM500 filters installed
HQ camera disassembly, part 1
HQ camera disassembly, part 2
HQ cameras in carriages
HQ carriages installation
No-ball plungers installation
Install no-ball plungers
Install carriages
Install carriages
Ball plungers installation
Secure ball plunger
Secure ball plunger
Brass spacers installation
StereoPi v2 installation to the backplate
StereoPi v2 with the spacers
Connecting HQ cameras' cables
Connect HQ cameras
Connect HQ cameras
HQ cameras with 5cm ribbon cables
Assembling the front and back together
Secure the backplate using metal screws
The result of the assembly
10cm and 5cm assemblies comparison
StereoPi v2 with HQ housing and two 6mm CS lenses
Installing 2" screen and shoot button
For the 2" screen and shoot button installation you can follow this section of the guide for the Camera Kit: Screen_and_shot_button_installation
