HQ housing assembly
Carriage and CM500 filter
A drop of glue
A drop of glue
CM500 filters installed
HQ camera disassembly, part 1
HQ camera disassembly, part 2
HQ cameras in carriages
HQ carriages installation
No-ball plungers installation
Install no-ball plungers
Install carriages
Install carriages
Ball plungers installation
Secure ball plunger
Secure ball plunger
Brass spacers installation
StereoPi v2 with the spacers
Connect HQ cameras
Connect HQ cameras
HQ cameras with 5cm ribbon cables
Spacers installation
StereoPi installation
Installing the 2" TFT screen
Installing the shoot button
Final assembly
