StereoPi v2 Quick Start Guide
- Install the RPIBOOT jumper
- Install the USB_CLI jumper
(1) BlueTooth power indicator
dtoverlay=disable-bt
(2) WiFi power indicator
(5) Hot-swap power LEDs
