StereoPi v2 Quick Start Guide
YouTube video: Power Switch
YouTube video: Hot Swap Power
Ribbon cable installation
(1) BlueTooth power indicator
dtoverlay=disable-bt
(2) WiFi power indicator
(3) Power On LED (4) ACT LED (5) Hot-swap power LEDs (6) 5V in LED (7) USB HUB LED
