HQ housing assembly
Carriage and CM500 filter
A drop of glue
A drop of glue
CM500 filters installed
HQ camera disassembly, part 1
HQ camera disassembly, part 2
Spacers installation
StereoPi installation
Installing the 2" TFT screen
Installing the shoot button
Final assembly
