HQ housing assembly
Carriage and CM500 filter
A drop of glue
A drop of glue
The ideal size of a drop is marked by 'A' in this photo.
The real drop example is marked by 'B'.
Put the IR filter into the carriage. Try not to leave fingerprints on the filter.
Spacers installation
StereoPi installation
Installing the 2" TFT screen
Installing the shoot button
Final assembly
