HQ housing assembly
HQ camera is able to see in IR and UV spectrum. But in this case, the colors of the image will be "abnormal". To fix this issue IR filter is used. In HQ camera it's a small piece (8.9mm x 8.9mm x 1mm) piece of glass. We included two such filter in HQ housing kit. They are exactly the same as ised in HQ camera.
