Revision as of 08:33, 7 October 2021 by Realizator (talk | contribs) (System)
Device settings, Stream, SRT
Device Settings, ZeroTier tab
  3. Put the "secret" to the second field.
  4. After the successful connection you can find the "PeerID" data on this page.
System (Device Settings)
Device Settings, System tab
