StereoPi v2 Camera Kit Guide
Revision as of 19:02, 28 September 2021 by Realizator (talk | contribs)
10mm spacers installation
Camera installation step 1
Camera installation step 2
Backplate installation
Tripod mount installed
Camera, spacers and bolts
Elevated camera assembly
Elevated cameras installed
Recessed camera installation
Screen installation: step 1
Secure the screen
Secure the screen
