StereoPi v2 Camera Kit Guide
10mm spacers installation
Camera installation step 1
Camera installation step 2
Backplate installation
Tripod mount installed
Camera, spacers and bolts
Elevated camera assembly
Elevated cameras installed
Recessed camera installation
Screen installation: step 1
