StereoPi v2 Quick Start Guide
- Install the RPIBOOT jumper
- Install the USB_CLI jumper
Do not use the micro HDMI to HDMI adaptor. Using it will increase the possibility of the micro HDMI connector physical damage. Most of the regular full-size HDMI cables are not flexible, and this adaptor will transmit all external physical load to the micro HDMI connector of StereoPi v2.
