StereoPi v2 Quick Start Guide
YouTube video: Power Switch
YouTube video: Hot Swap Power
  • Download, unarchive and put to the /boot partition of RaspiOS this file dt-blob.bin This file explains to the system how to access both cameras.
  • Open the file /boot/config.txt and add this row:
