StereoPi v2 Quick Start Guide
Please note that you can't use the micro SD card if your CM4 is eMMC-equipped! If you are using CM4 with the onboard storage (eMMC), you need to turn on the usbboot mode. To do this:
- Install the RPIBOOT jumper
- Install the USB_CLI jumper
