StereoPi Specifications
Revision as of 09:21, 25 May 2020 by Realizator (talk | contribs) (Camera Support:)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
Features & Specifications
Raspberry Pi Compatibility:
  • Raspberry Pi Compute Module 1
  • Raspberry Pi Compute Module 3
  • Raspberry Pi Compute Module 3 Lite
  • Raspberry Pi Compute Module 3+ 8 GB / 16 GB / 32 GB eMMC flash
  • Raspberry Pi Compute Module 3+ Lite
Dimensions:
  • width x length: 90 mm x 40 mm
  • height: 23 mm (standard edition) / 15 mm (slim edition)
Video:
  • input: two 15-pin CSI-2 camera connectors
  • output: HDMI
Camera Support:
  • Raspberry Pi camera V1 (OV5647 sensor)
  • Raspberry Pi camera V2 (Sony IMX 219 sensor)
  • Raspberry Pi HQ camera (Sony IMX 477 sensor)
  • IMX219-based Waveshare cameras for the Jetson Nano
  • HDMI video capture module (single mode, on Toshiba TC358743XBG chip)
Connectivity:
StereoPi Regular Edition:
  • GPIO: 40-pin classic Raspberry Pi header
  • USB: 2 x USB Type-A, 1 x USB pin header
  • Ethernet: RJ45 jack
StereoPi Slim Edition:
  • GPIO: no GPIO pins; soldering points for 40 GPIO
  • USB: 1 x USB pin header; soldering points for 2 USB Type-A connector
  • Ethernet: no RJ45 jack; soldering points for RJ45 jack
Storage:
  • microSD card slot (accessed by Raspberry Pi CM3/3+ Lite)
Power:
  • 5 VDC input via two-pin header
  • manual power switch
Software:
  • firmware update via Micro USB connector
  • runs standard Raspbian
StereoPi Pinout
StereoPi Front Noted
StereoPi Top Noted
StereoPi Top Noted
A. boot mode jumper
B. camera 1 CSI-2 connector
D. 5 VDC power connector
E. power switch
F. microSD slot
G. RJ45 Ethernet jack
H. dual USB Type-A connector
I. HDMI out
J. USB port pin header
K. camera 2 CSI-2 connector
L. 40-pin RPi GPIO header
M. RPi Compute SO-DIMM connector
StereoPi GPIO pinout
StereoPi GPIO
StereoPi GPIO
USB pins, power pins
StereoPi USB pins, power pins pinout
