DIY Ninjas Section
Revision as of 16:04, 10 September 2019 by Realizator (talk | contribs) (Schematic of the StereoPi board)
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
CM1 and CM3 VBAT power
R15 resistor StereoPi
R17 resistor StereoPi
StereoPi usb switch
StereoPi usb switch
DTS source file
List 1 (main/CM)
List 2 (power)
List 3 (usb/lan)
