StereoPi Specifications
Features & Specifications
Raspberry Pi Compatibility:
- Raspberry Pi Compute Module 1
- Raspberry Pi Compute Module 3
- Raspberry Pi Compute Module 3 Lite
- Raspberry Pi Compute Module 3+ 8 GB / 16 GB / 32 GB eMMC flash
- Raspberry Pi Compute Module 3+ Lite
Dimensions:
- width x length: 90 mm x 40 mm
- height: 23 mm (standard edition) / 15 mm (slim edition)
Video:
- input: two 15-pin CSI-2 camera connectors
- output: HDMI
Camera Support:
- Raspberry Pi camera V1 (OV5647 sensor)
- Raspberry Pi camera V2 (Sony IMX 219 sensor)
- HDMI video capture module (single mode, on Toshiba TC358743XBG chip)
Connectivity:
StereoPi Regular Edition:
- GPIO: 40-pin classic Raspberry Pi header
- USB: 2 x USB Type-A, 1 x USB pin header
- Ethernet: RJ45 jack
StereoPi Slim Edition:
- GPIO: no GPIO pins; soldering points for 40 GPIO
- USB: 1 x USB pin header; soldering points for 2 USB Type-A connector
- Ethernet: no RJ45 jack; soldering points for RJ45 jack
Storage:
- microSD card slot (accessed by Raspberry Pi CM3/3+ Lite)
Power:
- 5 VDC input via two-pin header
- manual power switch
Software:
- firmware update via Micro USB connector
- runs standard Raspbian
StereoPi Pinout
A. boot mode jumper
B. camera 1 CSI-2 connector
D. 5 VDC power connector
E. power switch
F. microSD slot
G. RJ45 Ethernet jack
H. dual USB Type-A connector
I. HDMI out
J. USB port pin header
K. camera 2 CSI-2 connector
L. 40-pin RPi GPIO header
M. RPi Compute SO-DIMM connector
