DIY Ninjas Section
DTS source file
Original StereoPi schematic was created in Altium, and now we're trying to choose appropriate open source tool. At this moment we tend to choose KiCad. If you have some ideas which tool should we use for opening our schematic, please let us know in out twitter here:
