DIY Ninjas Section
CM1 and CM3 VBAT power
R15 resistor StereoPi
R17 resistor StereoPi
StereoPi usb switch
StereoPi usb switch
You can easily access CM's USB on MicroUSB connector. You need to unplug power cable, and connect StereoPi's MicroUSB cable to computer without installing USB SLAVE jumper. In this case DD4 USB switch will connect CM's USB pins directly to MicroUSB connector. In this case USB and LAN will be disabled, and you can use usb-gadget API to turn on RNDIS LAN, usb camera or other modes on StereoPi according to your aim.
DTS source file
https://twitter.com/StereoPi
