Tip1: Not all MicroSD marked as 16Gb have the exact same size. Win32DiskImager may warn you that your MicroSD is too small, but you have the option to “continue record”. For this case we leave several hundreds of unused space at the end of MicroSD, so image will not be broken on such a cards.
