Revision as of 18:20, 6 February 2019 by Realizator (talk | contribs)
  1. Write image to MicroSD. As a Pi user, you might know, that it does not mean “copy-paste” image file, but requires special image writing software. Under Windows we prefer to use Win32DiskImager.
