Revision as of 07:44, 7 October 2021 by Realizator (talk | contribs) (Storage)
Device settings, Stream, SRT
Micro SD card will be used if no USB drive detected, and USB drive if detected.
All photos and videos will be recorded to the micro SD even if USB flash drive is detected.
Note: At the very first boot SLP2 formats all free space of the micro SD card to FAT32 and use this partition for the storage. It means you can connect this micro SD card to your computer using a cardreader and can access all your photos and videos.
