Revision as of 09:07, 6 October 2021 by Realizator (talk | contribs) (WiFi)
In this field, you can choose the country for the Access Point. This option is needed if you have some specific WiFi regulation rules in your country and special WiFi frequency bands. You can find only 3 options here: EU, US and CN. Please do not change this option if your WiFi connection works fine.
