Revision as of 08:31, 6 October 2021 by Realizator (talk | contribs) (WiFi)
System Note: to adjust the WiFi setting using this tab, please connect to the StereoPi v2 using Ethernet!
WLAN Note: to adjust the WiFi setting using this tab, please connect to the StereoPi v2 using Ethernet!
Access point Note: to adjust the WiFi setting using this tab, please connect to the StereoPi v2 using Ethernet!
