"supported 2" means that the system is configured correctly and "knows" about 2 cameras. This literally means that the dt-blob.file in the /boot partition has information about this
"detected 2" means that the system detected both cameras. If you see "detected 1" or "detected 1", this usually means one of your cameras has connection issues. Check the ribbon cable connection on the StereoPi side and on the camera side.
Imagine you have 1280x720 resolution for each camera. When you request the stereoscopic frame, the system takes 640x720 from the first camera by cropping it, and 640x720 from the second camera by cropping to. After that these "cropped" images are stitched together into one 1280x720 frame. I.e. in this case you are losing the field of view. This is "no decimate" mode, turned on by default. If you turn on
