Image specific
This simple application automatically connects to Pi with SLP image, requests video livestream and show it. If you use StereoPi and “3D” mode enabled in Admin panel – you can enjoy 3D video by putting your phone to google cardboard-like device. We like ColorCross and Pocket 360 solutions.
If you use classic Pi you can see video livestream from your camera.
Compatibility
Performance notice
