Image specific
This simple application automatically connects to Pi with SLP image, requests video livestream and show it. If you use StereoPi and “3D” mode enabled in Admin panel – you can enjoy 3D video by putting your phone to google cardboard-like device. We like ColorCross and Pocket 360 solutions.
If you use classic Pi you can see video livestream from your camera. We use either this ColorCross viewer or compact solution:
<><>ФОТО<><> <><>ФОТО<><>
Compatibility
Performance notice
