Revision as of 14:02, 29 April 2019 by Realizator (talk | contribs)
SLP Administration panel
Until you removed your MicroSD, you can also turn on stereoscopic mode instead one-camera mode right here, in configuration file.
and change 2D to 3D:
video_width=1280
video_height=720
video_fps=30
video_bitrate=3000000
video_profile=baseline
rtmp_url=
rtmp_enabled=0
mpegts_enabled=0
rtsp_enabled=0
usb_enabled=1
audio_enabled=0
video_wb=auto
exposure=auto
contrast=-15
sharpness=0
digitalgain=0.0
wifi_iface=wlan0
wifi_ssid=WIFI-NAME
wifi_psk=WIFI-PASSWORD
record_enabled=1
record_time=30
dec_enabled=0
up_down=0
udp_clients=192.168.1.10:3000
udp_enabled=0
ws_enabled=1
