Image specific
<><>СКРИНШОТ<><>
If you did not removed prepared MicroSD from your computer, you should now go to “BOOT” disk and find “stereopi.cfg” file. Open it and write your WiFi access point name and password in this rows:
<><>ФОТО<><> <><>ФОТО<><>
Compatibility
Performance notice
