Frames Per Second settings for video. Please notice, that if you choose too high FPS for high resolution you may obtain capture problems. For 1280x720 with ONE camera you may use 48 FPS. For 1280x720 and 3D use 42 FPS. You can experiment with these settings to fit your needs. We want to notice that highest FPS is critical for at least two scopes. First one is livestream to VR helmets like Oculus, as ease of perception depends on this. The second one is RC FPV, as higher FPS decrease video latency.
